D14 Mystery Lever
roon
03-12-2003 17:58:07
I was working on my tractor starter this weekend and found a lever on top of the hydraulic unit that I do not know what it is for. The lever is flat and parallel to the ground and has a rod that goes down into the torque tube near the hydraulic pump. It is located under the gas tank and to the left of the starter. I am thinking maybe it has to do with the traction boost system. Could this be used for the remote hydraulic output on the back of the near the 3 point?
Thanks in advance,
Roon
easyboy
03-13-2003 16:13:24
 Re: D14 Mystery Lever in reply to roon, 03-12-2003 17:58:07
belt pulley lever
JMS/MN
03-13-2003 06:18:34
It is for shifting the belt pulley in and out of gear. If you have a pulley, you need to push in the clutch to shift it into gear. It is not independent of the drive system.
JMS/MN
03-14-2003 05:25:04
 Re: Re: D14 Mystery Lever in reply to JMS/MN, 03-13-2003 06:18:34
This is why buyers should also get the OPERATOR manual- it explains all controls of the tractor, as well as basic maintenance and operation.
DanD.
03-12-2003 20:05:28
I think you're looking at the shifter for the belt pulley unit. WHen equipped with the belt pulley, a rod extends from that lever out through the dash. There should be a small hole on the lower right portion of the dash that has a plug in it. The rod passes through that hole and there is a knob on the end for putting the belt pulley in and out of gear.
wdTom
03-12-2003 18:02:09
And what happens when you move the lever?
roon
03-12-2003 18:23:13
 Re: Re: D14 Mystery Lever in reply to wdTom, 03-12-2003 18:02:09
Tom, right now nothing happens, I have the electrics out of the tractor rewiring and rebuilding the starter. Will be about a week or two before I get her back together.
Thanks,
Roon
