Is it a "B", or a "C"
Rob Timm
04-07-1998 21:45:31
Several years back my father purchased a "C" AC he thought. Well, since I have "Growed Up", I have been looking at that tractor in a different way. From the steering whell and battery box forward, it is the correct configuration for an AC "B", right down to the wide front. BUT, the rear end is a "C", at least the SN starts with a "C". Anybody have any answers to this Quetion that I have been pondering for a while now? Thanks.
Rob
robert mull
04-19-1998 09:16:07
 Re: Is it a "B", or a "C" in reply to Rob Timm, 04-07-1998 21:45:31
: Several years back my father purchased a "C" AC he thought. Well, since I have "Growed Up", I have been looking at that tractor in a different way.
: From the steering whell and battery box forward, it is the correct configuration for an AC "B", right down to the wide front.
: BUT, the rear end is a "C", at least the SN starts with a "C".
: Anybody have any answers to this Quetion that I have been pondering for a while now?
: Thanks.
: RobI have a "B" with adjustable front axle and the rears are adjustable and have multible lug bolts. It is a one row tractor but the tread with on mine is adjustable from 40" to 60"
thanks robert mull
greg
04-16-1998 19:15:23
 Re: Is it a in reply to Rob Timm, 04-07-1998 21:45:31
The rear wheels of the B and C attach to the drive
axles differently. The B wheels slip on to the
splined drive axles and are held on by a big nut.
The C wheels attach to the flat ends of the drive axles
with multiple fasteners.
I found this out when looking for a replacement for our
B which had a wheel with the spline torn out. B and C
share some parts, but as I found out, they don't share
axles and wheels.
greg again.
05-02-1998 20:30:52
 Re: Re: Is it a in reply to greg, 04-16-1998 19:15:23
I am looking at a picture of a '43 b in a book
and see a b with the rear wheels held on by a
5 bolt circle. So I guess you can't identify
a b by how the rear wheels bolt on. Sorry for
the mis-information.
Keith
04-08-1998 20:53:25
i was just reading my "operating instructions, maintnance, and parts illustration book" for the allis chalmers model C, and on page 33 it shows the optional wide front end, so what you have is a wide front end c. what is stamped on the engine? if your interested, i would be willing to trade my original allis chalmers c manual for an original ca manual.
Matt
04-10-1998 05:32:10
 Re: Re: Is it a "B", or a "C" in reply to Keith, 04-08-1998 20:53:25
: i was just reading my "operating instructions, maintnance, and parts illustration book" for the allis chalmers model C, and on page 33 it shows the optional wide front end, so what you have is a wide front end c. what is stamped on the engine? if your interested, i would be willing to trade my original allis chalmers c manual for an original ca manual.
I had the same problem at first. The c has an adjustable wide front axle, the b has a solid wide front axle. Most everything else is the same.
Rick
04-15-1998 07:28:03
 Re: Re: Re: Is it a "B", or a "C" in reply to Matt, 04-10-1998 05:32:10
I have a B manual and a 1941 B tractor that has an adjustable wide front end.
: : : i was just reading my "operating instructions, maintnance, and parts illustration book" for the allis chalmers model C, and on page 33 it shows the optional wide front end, so what you have is a wide front end c. what is stamped on the engine? if your interested, i would be willing to trade my original allis chalmers c manual for an original ca manual.
: I had the same problem at first. The c has an adjustable wide front axle, the b has a solid wide front axle. Most everything else is the same.
keith
04-10-1998 10:21:21
actually, b's had solid and adjustable front ends.
Lloyd Wheeler
04-17-1998 17:42:25
 Re: Re: Re: Re: Is it a "B", or a "C" in reply to keith, 04-10-1998 10:21:21
: actually, b's had solid and adjustable front ends.
Fellas, You've overlooked the basic difference...a "B" is a one row tractor (narrow) and a "C" is a two row tractor (wider). All that aside, the easy way to tell is that the steering arm on the steering box points down on a "B" and up on an "A". Lloyd
Rob Timm
04-21-1998 14:12:09
 Re: Re: Re: Re: Re: Is it a "B", or a "C" in reply to Lloyd Wheeler, 04-17-1998 17:42:25
Gentlemen, The front axle on mine isn't adjustable. It has a boed front axle like a "B". I am going to check and see how the reaer's are attached, cuase right now I couldn't remember to save my soul.
Rob
: : actually, b's had solid and adjustable front ends.
: Fellas, You've overlooked the basic difference...a "B" is a one row tractor (narrow) and a "C" is a two row tractor (wider). All that aside, the easy way to tell is that the steering arm on the steering box points down on a "B" and up on an "A". Lloyd
