Allischalmers -gas in oil
jon
03-11-2003 15:32:28
At our shop we have an allis chalmers fork lift, it has some problems and hope someone can help me figure this out. Its a model FL40-24PS....serial # is 39365000....engine is a G153, at least that is what I was told. The problem is the crankcase fills up with gas after a short period of time. I thought maybe it was from the fuel pump so i changed it. worked for a while and now have gas in the oil again. I know this isn't good on the bearings but we don't use it every day and when we do it might be for 10-20 minutes at a time. I am not sure if this is the same engine that they used on some of the tractors or not, hope someone can help. Thanks
Steve in N.J.
03-11-2003 17:08:00
 Re: allischalmers -gas in oil in reply to jon, 03-11-2003 15:32:28
Jon, We had a Hyster forklift that did the same thing. You mentioned that you changed the fuel pump. Was it electric or mechanical? Reason why I ask, our Hyster is equipped with an electric fuel pump, and when the pump went bad, it increased the fuel pressure higher than the pressure regulator on the machine was set for, and started pushing fuel down the carburator after it was shut off. It seem to run fine when we were using it, unaware at first what was happening. After the pressure came down from sitting a while (from leaking down the carb)eventually the crankcase level started to get higher little by little. We caught it before any damage was done, but that's what happened to us. Could also be to high a float level and fuel is seeping by the needle & seat while it sits.
Just a thought..... . Steve B.
jon
03-11-2003 18:39:37
 Re: Re: allischalmers -gas in oil in reply to Steve in N.J., 03-11-2003 17:08:00
Steve, it is a mechanical fuel pump, also when i started working there the carb ran over all the time so i rebuilt it with new float ,needles and seats. I first thought that to so I shut the fuel tand off over the weekend and it didn't seem to help. We have a 2510 Deere that did the same and the fuel pump fixed it's problem. Thanks for the feed back, jon
Mike (WA)
03-12-2003 08:18:38
 Re: Re: Re: allischalmers -gas in oil in reply to jon, 03-11-2003 18:39:37
Is it an updraft carburetor? If so, it can't be the problem and I would suspect fuel pump (maybe an early failure on the replacement pump).
steve
03-12-2003 17:06:02
 Re: Re: Re: Re: allischalmers -gas in oil in reply to Mike (WA), 03-12-2003 08:18:38
if it is a mechanical pump like a car engine, it could have a ruptured diaphram and be leaking right into the crank case. i would pull the pump and check.
