Conservation/restauration of ACB model
pierre le gouai
03-10-2003 13:55:10
student at l'Ecole du Louvre in Paris (France) to be responsible later on of a museum,i'm trying to restorate an AC B model built in 1949 and sold in France buy general Marshall's Plan. at the moment i'm studying on how to prevent from rust crumbling without taking the paint of the AC.If someone has any idea or wants to send any e mail to me on the subject,he is welcome.if someone wants to know about AC tractors in France,he is welcome too.
Chris
03-13-2003 07:59:44
 Re: conservation/restauration of ACB model in reply to pierre le gouaille, 03-10-2003 13:55:10
I am not completely understanding your question. Are you wanting to preserve the tractor in its current condition? You want to halt the rusting with out removing the rust and the paint? Leaving the tractor in a used looking condition? If this is the case and the rust is not crumbly I suggest coating the tractor with WD-40 spray . This will stop the rust and improve the condition of the existing paint.The WD-40 will have to be reapplied periodically.
le gouaille
03-13-2003 14:31:22
 Re: Re: conservation/restauration of ACB model in reply to Chris, 03-13-2003 07:59:44
Chris you are wright, the prospect is to leave this AC in what we call in a Museum "the last stage" in the life of the object. My question is will WD 40 spray attack the paint or anything on the tractor once it will have been put on it ? Could you give me the entire name and the name of the factory or company which is making this product? thanks for all Pierre.
ed
03-11-2003 16:31:20
I have an allis b tractor and as of yet have done nothing with it other than run it. I'm sorry I can't help with your tractor.
I do have a question in regards to the "overseas" tractors. I have a book that is written with pictures of most tractors from I believe England. They have allis b and c tractors pictured. My question is on the side with the oil filter mounted just above the filter in the sheet metal are three bolts. They are in the shape of a triangle and are holding something under the hood. I do not have them on the tractor I have, or on any one I have seen in the states. I thank you for your time. ED
TractorMike
03-12-2003 17:56:45
 Re: Re: conservation/restauration of ACB model in reply to ed, 03-11-2003 16:31:20
ed, The bolts in the shape of a triangle are for a gasoline starting tank for the dual fuel (kerosene or distillate) engine. You started the engine on gas and after the engine got up to operating temperature you switched it over to kerosene. I have a 1941 US C that has the dual fuel engine and it still has the hood with the holes for the starting tank. Hope this helps, TractorMike
pierre le gouaille
03-13-2003 14:36:06
 Re: Re: Re: conservation/restauration of ACB model in reply to TractorMike, 03-12-2003 17:56:45
thanks a lot tractorMike for your answer to Ed this will help me too
TractorMike
03-13-2003 16:12:11
 Re: Re: Re: Re: conservation/restauration of ACB model in reply to pierre le gouaille, 03-13-2003 14:36:06
Your welcome, Glad I could be of some help. TractorMike
ed
03-12-2003 20:43:23
What did the us do just use the gas only? At the pump price today maybe we should go back to kerosene. ED
pierre le gouaille
03-13-2003 14:41:16
 Re: Re: Re: Re: conservation/restauration of ACB model in reply to ed, 03-12-2003 20:43:23
in France at the time, we used to start on petrol then work on kerosene.
pierre le gouaille
03-12-2003 05:12:57
dear Ed
i'm not clever enought in AC "B" to answer right now to your question but 'ill do my best and ask a mecanician in a tractor museum. all i know is that most of our "french" AC where coming from canada and gb after 1951 and before straight from the states.
ed
03-12-2003 14:07:27
 Re: Re: Re: conservation/restauration of ACB model in reply to pierre le gouaille, 03-12-2003 05:12:57
Thanks. ED
ed
03-11-2003 16:30:19
I do have a question in regards to the "overseas" tractors. I have a book that is written with pictures of most tractors from I believe England. They have allis b and c tractors pictured. My question is on the side with the oil filter mounted just above the filter in the seat metal are three bolts. They are in the shape of a triangle and are holding something under the hood. I do not have them on the tractor I have, or on any one I have seen in the states. I thank you for your time. ED
