Wiring Diagram For A WD45
Roger
03-09-2003 17:23:04
I need a step by step diagram for where each wire goes. This diagram needs to be for a WD45 with a distributer. Thanks, Roger
JMS/MN
03-09-2003 21:10:51
 Re: Wiring Diagram For A WD45 in reply to Roger, 03-09-2003 17:23:04
Buy the OPERATOR manual. Contains the wiring diagram and much more. Don't mean to harp on you personally, but so many of these questions could be answered if people would just spend $15 on the manual to learn how to operate, service, and adjust their tractors. I figure if someone can spend $1000 or more for a tractor, they should have the price of a case of beer to learn how to run and service it!
steve
03-09-2003 19:53:28
I will send you a diagram for a C from the mid 1940s that has 6 volt positive ground, with the light switch and cutout for the generator charging. It should be very very close, if someone else does not send you a WD45. IF you need a description of how the generator or light swithc works, just ask.
