Controls on d14
Pete
03-09-2003 09:30:06
Hi, There are two levers, one is the lift lever for the 3-point hitch, the other lever is above the lift lever and it has teeth that it fits into. Does anyone know what this lever does?
Also, I have a gauge that says traction booster. I can see that it once hooked up. How should this be hooked up?
Should I hook it up?
What type of info does it show?
Which manual for the D-14 gives the most information on operation and rebuilding?
Thanks in advance,
Pete
Gordon-(TN)
03-09-2003 19:07:55
 Re: controls on d14 in reply to Pete, 03-09-2003 09:30:06
Pete
The lever above the lift lever is the traction booster the gauge in the lower right is to show the amount of pressure on the traction booster. This works like the draft control on Ford and Massey Ferguson, It will lift the plows out of the ground if pushed all way up. Hope this helps Gordon-(TN)
Gordon-(TN)
03-09-2003 19:07:31
Pete
