AC Gear Shift Boot
Muffy
03-08-2003 16:17:15
Does anyone know where I can get a rubber gear shift boot for an AC B-Model?Thank you in advance for your help. Muffy
stevec
03-09-2003 15:26:08
 Re: AC Gear Shift Boot in reply to Muffy, 03-08-2003 16:17:15
hey muff, you can get one at tractor supply. it is very reasonable in price. good luck stevec
jimg
03-09-2003 08:34:03
I bought a shifter boot from a parts guy in the flee market at our show. So whats the problem? I can't get the darn knob off the shift lever to put the boot on.. The knob is good and didn't want to ruin it.
Farmered
03-11-2003 04:45:59
 Re: Re: AC Gear Shift Boot in reply to jimg, 03-09-2003 08:34:03
Shift to the neutral position. Remove the lever retainer and pull the shift lever out. Replace the boot from the bottom of the lever and reinstall. Be carefull not to lose the allignment pins which engage slots in the sides of the ball shaped area of the lever. Good luck Ed
Muffy
03-09-2003 12:17:16
So how did you get the knob off????Muffy
Farmered
03-21-2003 02:09:12
 Re: Re: Re: AC Gear Shift Boot in reply to Muffy, 03-09-2003 12:17:16
Read my reply again. I didn't take the knob off.
I put the boot on from the bottom. If you use force on the knob you risk breaking it.Be glad the knob is tight. I hate knobs that keep loosening up. Ed
AWB
03-09-2003 05:25:40
Gear shift boots are still available from AGCO.
Gordon
03-08-2003 19:13:41
Sandy lake equipment has about everything you need
Dale
03-08-2003 16:20:17
Any AGCO dealer should be able to get one.
