WC Ignition
John IL
03-07-2003 18:38:31
I'm new to AC so please bare with me. Did all WC'S come with a mag? If not when did they switch to a dist? I looked at a WC today. The serial number looked like 100463. 1940 I think. It had a dist. a battery, generator and it sure looked like a starter. Could all this stuff have been factory? Thank you very much. John Kauzlaric
Farmall Daddy
03-09-2003 11:23:01
 Re: WC Ignition in reply to John IL, 03-07-2003 18:38:31
All WC's {that I am aware of} came from the factory with a magneto. You can adapt a WC to have a distributor, and still have the generator on it, but in my own opinion, a WC is better with the mag. Just my two cents.
Sid
03-08-2003 02:00:40
A distributor can be put on a WC. Even though it is not factory.
Steve in N.J.
03-07-2003 20:11:52
John, If my notes here are correct, the WC series machines were all magneto. Fairbanks versions were FMK4B3, FMJ4B3, or FMJ4B3A. (At least that's the 3 versions so far that I've been rebuilding from that particular tractor for folks) HTH Steve/B&B Custom Circuits
John (C-IL)
03-07-2003 19:44:06
The distributor was introduced on the WD at serial #136318. The ignition on all WCs was a magneto. One thing to check is if the engine is a WC or not. Not sure on the engine serial number, but I think the WD engine starts with WD the WD45 with 45 and so on.
kevin
03-07-2003 19:04:18
John,
I can't address the ignition for sure, but battery, lights and starter were added in '38. So, distributor ignition could have been added then or shortly after.
Kevin (FL)
DanD.
03-08-2003 03:57:30
 Re: Re: WC Ignition in reply to kevin, 03-07-2003 19:04:18
WC's never came with a distributor from the factory. Many had them added on later on, however. In fact, you could get a distributor drive (I have one in fact) that bolts right on where the magneto goes. It takes all of 5 minutes to change from magneto to distributor or vice versa with one of those set ups.
