C or ca
brent(pa)
03-05-2003 22:42:39
I recently bought this tractor. The guy said it was a ca but I think it is a c. The only serial# I can get off it is 75830 in this order and this is off the transmission in front of the shifter but I cant find it in any of the b,c,or ca serial# lists. PLEASE HELP
Mike in Pa
03-06-2003 16:46:03
 Re: c or ca in reply to brent(pa), 03-05-2003 22:42:39
Unless someone changed something a C has a 3 speed trans and the CA models have a 4 speed trans.Also the CA has floor pan sheet metal on and around the rear housing where the C does not.
Reub
03-06-2003 10:15:51
The easy way to tell a C from a CA is the rear wheels. The CA has a six bolt lug pattern the power adjust rims. The C had a five bolt pattern and standard rims
alan
03-06-2003 03:44:39
looks like a 49 c. also, a ca will have a 4 spd trans, a hand clutch, and a pan seat; the c will have a 3 spd trans, no hand clutch, and a bench seat; also there were only 40 some thousand ca's made. serial number won't go that high. alan
tom davison
03-06-2003 09:31:26
 Re: Re: c or ca in reply to alan, 03-06-2003 03:44:39
I believe there were approximately 84,000 C,S Built.
tom davison
03-06-2003 09:29:50
I believe there were approximately 84,000 C,s built.
Tom Davison
