Re: 12 Volt Conversion Kit for1950 WD.
steve
03-05-2003 19:50:07
the alternator of choice is a DELCO 10SI which was common on most general motors cars and trucks from 1975 to 1985. You can get one at Auto Zone for $40. ask for 1975 chevy truck alternator, basic, no options (probably 40 amp output). You can do the wiring yourself, or have it made if you are not comfortable with that. There is a big charge wire, about 10 gauge from the alternator big terminal to the ampmeter-battery, and then two smaller wires. One small jumpered to the big +12 terminal, and the other one has a dropping resistor and goes to the key or togglel off switch. This wire must be shut off when tractor motor is off. I will send you a simple picture of wiring.
