WD45 tires
Rod
03-05-2003 18:53:14
Did any of the 1953 model WD45's come with 14.9-28 tires
JMS/MN
03-07-2003 05:54:05
 Re: WD45 tires in reply to Rod, 03-05-2003 18:53:14
12-28 was standard, 13-28 was an option. Current size marking on a 13-28 is 14.9-28.
kendall
03-06-2003 11:25:30
Yes all 45's came with 13-28 which was replaced by 14.9-28.
Phill S. from MN
03-07-2003 14:15:59
 Re: Re: WD45 tires in reply to kendall, 03-06-2003 11:25:30
What about 16.9 x 28? I remember my uncle's WD-45 having really wide, large tires. I think his tires were original, but I don't know for sure.
Would the 16.9's look out of place or too oversized on my WD-45? Is there a lot of size difference (height or width)between the two sizes?
Thanks for your advice.
dan
03-17-2003 18:31:48
 Re: Re: Re: WD45 tires in reply to Phill S. from MN, 03-07-2003 14:15:59
we have 9 45s in the family only 2 of them have 13.6 28s the rest are 14.9s dads orginal tires are 14.9s and we use 16.9-28s for duals 14.9 is a tall tire 16.9 is lower the duals match fine to put 16.9s on a 45 you would need larger rims
