Allis B hydraulic pump
TractorMike
03-04-2003 16:50:03
I just put on another hydraulic pump on my B Sunday and today was the first day I got to try it out, But when I engaged the PTO after the pump primed I noticed that the pump never stopped pumping fluid no mater what position I put the hydraulic lever in. So I was wondering, Does the pump always pump fluid but with an implement hooked up you notice it??? Or does my pump need an adjustment? Thanks, TractorMike
steve
03-04-2003 18:44:33
 Re: Allis B hydraulic pump in reply to TractorMike, 03-04-2003 16:50:03
the pump is driven off a cam on the PTO shaft. if the PTO is engaged, the pump is pumping. when you engage the hydraulic lever, it closes off the sump and the line builds up pressure. when you push the lever back down, it moves the spool and the oil leaks back to sump, and pressure drops to zero.
TractorMike
03-05-2003 04:57:20
 Re: Re: Allis B hydraulic pump in reply to steve, 03-04-2003 18:44:33
Thanks Steve, TractorMike
