1955 WD-45 Wiring Help
Chad
03-04-2003 08:18:02
We have a 1955 WD-45 that the wiring is a total Mess. I am tired of charging the battery everytime we use the tractor. I have worked on many farmall 6-volt generators and I know that when I get them wired up right they work great.
I am sure once I figure this WD-45 out and have it wired correctly it will work just as good. does anyone have a wire diagram for this tractor?
Thanks
Chad
Duey (IA)
03-04-2003 10:16:32
 Re: 1955 WD-45 Wiring Help in reply to Chad, 03-04-2003 08:18:02
Chad Also be sure to ground the dash box to the battery box. This is required for the manual field resister on the light switch to function. The resister must work for the generator to charge. The cutout relay on the generator also must function for the generator to operate and also to stop the backfeed from the battery to the generator when the engine is not running. Duey
Duey (IA)
03-04-2003 10:08:10
Chad,
Ther's a wire diagram on my web page. Duey
Chad
03-04-2003 10:28:39
 Re: Re: 1955 WD-45 Wiring Help in reply to Duey (IA), 03-04-2003 10:08:10
Duey
thank you very much! that is exactly what I am looking for! thanks again
I also asume that I will need to ploarize the generator like I do on my farmall's and my vw engines!
thanks
Chad Penny
