WD Plug Wires: Do they need to be solid copper?
Kevin
03-03-2003 07:18:32
I just replaced the plug wires on my WD with current day automotive type. I took the solid copper wire type off. My initial use after that, it was not operating at full power and was a little hard to keep running. Later I cleaned and re-gapped the plugs, cleaned and gapped the points, and it seems to be okay. Any ideas?
Steve in N.J.
03-03-2003 14:25:30
 Re: WD Plug Wires: Do they need to be solid copper? in reply to Kevin, 03-03-2003 07:18:32
Kevin, Most definetely use solid core wires. Especially if your tractor is equipped with a magneto. I make spark plug wire sets specifically for AC machines. Mag or Distributor. Drop us a line if interested....Steve/B&B Custom Circuits
Dave K
03-03-2003 13:23:22
You really need to use the solid wire core ign wires. Those with the carbon center provide too much resistance and a weaker spark. Particularly if your WD has a magneto.
Dae
