WD, ENGINE SERIAL # LOCATION?
MIKE DAVIS
03-03-2003 03:28:53
Where is the serial # of the engine located? Can't find any reference to the location in the books. There is a raised retangle space on the block, left side aft that is blank. Thanks!
Brian G. NY
03-03-2003 05:57:17
 Re: WD, ENGINE SERIAL # LOCATION? in reply to MIKE DAVIS, 03-03-2003 03:28:53
The raised "boss" is on the side of the block just below the hose fron the air cleaner to the Carb. The numbers are stamped (sometimes faintly) into this area. You will have to scrape to make it out as the numbers often are filled with paint. There will be no number in some cases where the engine or block has been replaced with new. I Have a WD-45 with no engine serial number.
MIKE DAVIS
03-03-2003 10:27:37
 Re: Re: WD, ENGINE SERIAL # LOCATION? in reply to Brian G. NY, 03-03-2003 05:57:17
Thanks for the information. This must be a replacement block. I thought that was the right location for the number but was just double checking. Thanks.
