Carb Kits??
Jeff May
03-16-1999 20:38:55
Can anyone recommend a source for rebuild kits for a Zenith carb on a "C"?
Thanks in advance, Jeff
al
03-21-1999 05:21:12
 Re: Carb Kits?? in reply to Jeff May, 03-16-1999 20:38:55
The advertises that make this page site possibles sale the kits.Click on parts & supplies.
Todd Doty
03-17-1999 20:48:44
Try your local NAPA I have had good luck getting Zenith carb kits from them.
RMD
03-16-1999 21:02:41
I found it was easier and cheaper to just take the carb to a local carburation shop and have them rebuild it. Much better job than I could have done and cheaper than than the prices I was seeing for kits.
Brian Watson
03-18-1999 16:52:08
 Re: Re: Carb Kits?? in reply to RMD, 03-16-1999 21:02:41
Carb kits aren't hard to do, provided you blow out all passage ways in the castings with compressed air. Don't use fishing line. If there are blocked passages in the carb fishing line won't remove it all. Also, don't try to stick anything sharp metal or otherwise into any passages. Soaking to clean is best, but sprays will do the job. Cleanliness is Godliness when reassembling. If your carb has lots of hard deposits in the bowl, here is a trick I found to work very well, with the main needle in place, fill the bowl with fresh battery acid. This will take almost anything out of the bowl that doesn't belong there. It doesn't take long, about 15 to 20 minutes. Acid can be had at NAPA. Follow the instructions in the kit. NAPA is a good place, or CT Farm and Country, TSC stores, or even this website's store has them. Nothing like the satisfaction of doing it yourself. Let us know how you come out, or e-mail me if you need more help. Brian
P.S. I've been ASE Certified in engine performance for the past 10 years. Good luck.
Jeff May
03-19-1999 03:52:17
 Re: Re: Re: Carb Kits?? in reply to Brian Watson, 03-18-1999 16:52:08
Brian;
your e-mail address wont allow me to mail you, Is it correct?
Brian Watson
03-20-1999 11:56:51
 Re: Re: Re: Re: Carb Kits?? in reply to Jeff May, 03-19-1999 03:52:17
Oops, goofed again. This one works; AlsChlmers @ aol.com Brian
Brian Watson
03-20-1999 11:35:52
Give this one a try. alschlmers @ aol.com. Every now and then I get it misspelled. I'm usually online Tuesday afternoon Thursday evenings and sporatically on the weekends. Brian
