D14 Oil Lines
roon
03-01-2003 19:41:01
Hello again, Trying to dry up some oil leaks on the old D14. Most of the oil lines are brass tubing with compression fittings, and many of them leak. Is there any type of thread sealant that I can use to prevent the leaks that will not cause problems with the oil? Should I just pitch all of the oil lines and put on new ones to stop leaks or is there another solution?
Thanks in advance
Roon
