D14 Starter Rebuild?
roon
03-01-2003 19:29:59
Hello, I decided to start rebuilding my 1957 D14 this spring. I thought that I would start with the part that has given me the most trouble, the starter. I took it off the tractor today, now must decide to rebuild or by a "reconditioned" starter. First if I decide to have starter rebuilt, could my local NAPA store do the work or do I pay double to triple the price to have the local AGCO dealer rebuild it (6V Positive ground)? Is there any advantage in keeping the original starter? If I buy a "reconditioned" starter who are my best sources, Norms Toys or Sandy Lake Imp? Also when I go to re-install the starter, is there any trick or special way to line up the bolt that holds the starter in place? And finally, where the battery connects to the starter there is another wire that runs to the ammeter, is this normal?
Thanks in advance for all the help,
roon
steve
03-02-2003 05:48:11
 Re: D14 Starter Rebuild? in reply to roon, 03-01-2003 19:29:59
you might try taking the end cover off and sliding out the armature yourself and looking around. some times you can put in new brushes, or sand the others smooth, then polish the armature or mount in a lathe and take off .020 inch or so to dress up the area where the brushes run. worse thing that can happen is you put it back to gether and take to to a rebuild shop. Why would NAPA be any different then AGCO? still have a warranty dont you?--i will send you a wiring diagram for the D14.
