AC B engine locked up, HELP!!
Jesse
03-01-2003 13:38:31
I recently inherited an old tractor ( it ran a little over a year ago), when I went to crank it I found that the engine had locked up. Upon closer look, the gasket on the oil pan needed to be replaced--apparently the oil leaked out. Is there a "miracle" oil of sorts to soak this engine in to free it up?
steve
03-01-2003 18:52:42
 Re: AC B engine locked up, HELP!! in reply to Jesse, 03-01-2003 13:38:31
if it really ran out of oil, you are out of luck. if it sat outside and "got stuck", pull the spark plugs and fill it with PB blaster, WD40 , diesel fuel, your choice. Remove the starter and try to bar the motor over with a prybar on the flywheel teeth every day, untill it moves. If you take off the oil pan, remove the center bearing cap covers and examine the bearings to see if it did run out of oil.
