D-15 oil change
Ed Weis
03-01-2003 06:53:07
What weight oil and how many quarts are needed for a diesel D-15, please? Should I use detergent oil? Any recomendations for a good operators manual? THANKS.
go
03-01-2003 11:27:11
 Re: D-15 oil change in reply to Ed Weis, 03-01-2003 06:53:07
to your AC/AGCO dealer for the OPERATOR manual. Seasonal oil info and everything else you need to know to operate it.
max (PA)
03-01-2003 10:28:24
just changed mine yesterday
9 qt. fram filter PH977A 10w-30w oil rated for Diesel use
Eldon
03-01-2003 17:38:06
 Re: Re: D-15 oil change in reply to max (PA), 03-01-2003 10:28:24
The problem with detergent oil is that it could loosen up sludge in the engine and possibly clog oil lines. If the engine has only run non-detergent or hasn't had a recent overhaul the risk increases. Non-detergent may be the safer way to go if this is the case..... I think D15 diesels are pretty pricey to overhaul..... just my opinion.
Ed Weis
03-01-2003 20:14:52
 Re: Re: Re: D-15 oil change in reply to Eldon, 03-01-2003 17:38:06
THANKS,Eldon. My Dad shares your views. I'm thinking I used non detergent oil last time, per his advice. Guess I'd rather be safe than sorry. Thanks again.
max (PA)
03-02-2003 04:45:27
 Re: Re: Re: Re: D-15 oil change in reply to Ed Weis, 03-01-2003 20:14:52
one thing is for certain, if you use non-detergent oil in your Diesel engine, a complete rebuild is going to happen in the near futher.....that's depends on if you havn't totally ruined your engine !
but, then again, signing up as a donor does help keep the rest of the fleet running.
Eldon
03-02-2003 09:03:07
 Re: Re: Re: Re: Re: D-15 oil change in reply to max (PA), 03-02-2003 04:45:27
Max are you saying that the diesels came with detergent oil in them from the factory?
max (PA)
03-02-2003 09:51:29
 Re: Re: Re: Re: Re: Re: D-15 oil change in reply to Eldon, 03-02-2003 09:03:07
non-detergent oils were sometimes reccommended for the inital start-up of new/rebuilt engines, only reason i'am aware of is that it was extremely cheap and was to be change out and discarded within the first few hours of operation.
I worked for a very large construction equipment manufacturer for 27 years, mostly in the engine- prep department, worked on John Deere, Cummins, Cat, Perkins, Deutz, Detroits, a V-12 air cooled monster i can't remember who manufactured, mitibishi, kabota, Briggs, Tucumsen...i can assure you all left the factory with 15w-40 detergent high TBN engine oil, EXCEPT, the John Deere which came from them already serviced with their oil of choice (?) I might add that they were also the most particular with their other lubricant requirements, and did spot tests regularly.
Eldon
03-02-2003 09:58:56
 Re: Re: Re: Re: Re: Re: Re: D-15 oil change in reply to max (PA), 03-02-2003 09:51:29
Thanks! When I had my D19 TD I used synthetic but I did a motor flush first. I haven't bought anything but oil for my Cummins lately.....maybe a non-detergent diesel rated oil isn't even available any more???
max (PA)
03-02-2003 10:39:57
 Re: Re: Re: Re: Re: Re: Re: Re: D-15 oil change in reply to Eldon, 03-02-2003 09:58:56
you would have to go out of your way to find it, or very lucky..lol
max
Ed Weis
03-01-2003 15:15:24
THANK YOU. Now I can change the oil while I shop for an operators manual. I was told to use non detergent, but will follow your advice. THANKS Ed.
Ed Weis
03-02-2003 19:06:59
 Re: Re: Re: D-15 oil change in reply to Ed Weis, 03-01-2003 15:15:24
Sorry if I stirred the pot about my non detergent oil question. Now I'm really confused.
