Re: W C Allis puller
Mervin
02-27-2003 17:46:08
Buford, The first problem your going to have is the D-17 crank won't work in your WC block. Pistons will fit the rods o.k. Clutch will hold if its in good cond. Carb off D-17 will work. WD-45 crank is what you need. Wd-45 head and manifold off WD-45 or D-17 will work too. Cam out of your D-17 will work in WC block. You will have to use the D-17 oil pump with it though. Any thing else you want to know let me know.
Dogdad
03-09-2003 16:16:23
 Re: Re: W C Allis puller in reply to Mervin, 02-27-2003 17:46:08
thank you for the information on what will fit into a WC engine.
Dad
