D-14 traction booster
Edward
02-25-2003 11:39:39
Still learning about my D-14. Dealing with the traction booster, the guage has the indicator needle stuck about mid-point on the dial. When moving the lever to engage booster, nothing seems to happen and the needle does not move. Any thoughts on where I need to start with this?
Thanks for the help guys.
DanD.
02-25-2003 12:45:07
 Re: D-14 traction booster in reply to Edward, 02-25-2003 11:39:39
The traction booster system won't function unless you have an implement like a plow or disc mounted via the snap coupler and it's in the ground pulling. It's the draft load that activates the system. To see if your gauge moves, just take your hydraulic lift lever and pick up the lift arms all the way. When they get to the end, the gauge should move all the way to the right.
