Pullin B
chuck
02-25-2003 09:39:30
im trying to put d17 pistons and sleeves in the B block will it work?Any help would be great
Phil Auten (TX)
02-25-2003 10:16:43
 Re: pullin B in reply to chuck, 02-25-2003 09:39:30
It's gonna be a tight fit! Depending on which block you have it will be necessary to rebore the sleeve holes for the D-17 sleeves. The early B had 3.25" bore and the late B had a 3.375" bore. The D-17 is 4" bore. You might be able to bore the B block for the larger sleeves, but I would start measuring real carefully to see if there will be enough room for the big sleeves to fit. I sorta doubt it, but I've never tried either.
Good luck,
Phil
