C-allis axle seals
rudy
02-23-2003 07:21:10
i need to replace the seals up by the ring gear and would like to get them ahead of time does anyone have the seal numbers?
steve
02-23-2003 20:14:14
 Re: c-allis axle seals in reply to rudy, 02-23-2003 07:21:10
CR12458 is the seal i have listed for the axle where it plugs into the differential housing on each side
rudy
02-24-2003 15:56:43
 Re: Re: c-allis axle seals in reply to steve, 02-23-2003 20:14:14
thanks to all
Dana (Iowa)
02-23-2003 15:33:41
Rudy - If you are talking about the large outter axle seals located right behind the wheel hub, the Chicago Rawhide number I used on my '47 C is 25043. I also have the Timken bearing and race part numbers for both the inner and outter bearings. Let me know if you need others. I have most of the part numbers from when I did my C last year (I figured someone else might benefit from all the time I spent at the bearing shop).
