I've installed my shifter and now....
kevin in Ontari
02-22-2003 15:21:56
Just finished installing my shifter on my wd45...learned alot. After alot of fiddling I seem to be able to get 1st and 2nd and reverse no problem (Tractor isn't running .. torn down) 3rd and 4th don't seem to lock in. I'm 99.9% sure I got the forks in the right position as just before I dropped the shifter on the last bit, I peeked in and everything was good. Also worked well when I first tried it. Any ideas.?????
Kevin
sHan
02-22-2003 17:19:58
 Re: I've installed my shifter and now.... in reply to kevin in Ontario, 02-22-2003 15:21:56
try turning the shaft or just bump the motor over just a hair and then try it sounds like the gears are not lined up ive had this proublem with truck trans before just my 2 cents..... ..
