12 volt conversion, WD Alternator
MIKE DAVIS, (ME
02-21-2003 14:28:54
Other than the cooling fins running backwards is there any reason an alternator shouldn't run just fine backwards? The cooling fins I figure is no big deal, not enough amps drawn on the alternator to really worry about cooling. I am new at this game so guys, take it easy on me please. I figure the only dumb question is the "ONE NOT ASKED". Thanks.
George G
02-22-2003 14:32:05
 Re: 12 volt conversion, WD Alternator in reply to MIKE DAVIS, (ME AGAIN!), 02-21-2003 14:28:54
I thought the same thing on my WD-45. Checked the one in my pick-up. Alt. run's the same way.
Doug in OR
02-22-2003 08:01:38
Why would your cooling fins be running backwards? A WD engine turns the same direction as any car engine that I've seen.
Paul Janke
02-22-2003 05:33:16
I have used alternators running backwards. They work fine. If the pulley has no key you may need to tighten it a little extra.
