Wd 45 baling hay
justin
02-19-2003 18:57:05
how good will a wd 45 run a jhon deere 336 square baler does the hand clutch make it alot easier to run the baler in thick windrows? on the hand clutch what is the differnce of having 3 or five plates?
Mike
02-21-2003 11:12:05
 Re: wd 45 baling hay in reply to justin , 02-19-2003 18:57:05
Your 45 will be able to pull it off on level ground. My neighbor had a 45 and 336 baler and it would pull a load of 150 bales. It was a pretty interesting sight because my uncle seen them hooked up and didn't believe it would run it.
good luck!
John (C-IL)
02-21-2003 05:57:47
Justin, The hand clutch is either 2 or 3 plates. WDs and early 45's had the 2 plate, later 45's had the 3 plate. Think about it, The 3 plate will have more surface area so should have more pulling power before slipping. They both run in an oil bath so that shouldn't be much of an issue. John
Jason
02-20-2003 19:12:33
I used my WD45 to bale using a New Holland Hayliner. I think it was a 225. I didn't have any major problems. I did break a couple of the bolts that hang the PTO shaft due to the tight turns I had to make with the bailer. They are a nice size to get in and out of smaller acreages.
big orange
02-19-2003 19:05:24
Ran a 315 NH with our 45,pulled a rack usually 120-130 bales low or second depending on crop,and you can slip the hand clutch in heavy spots.
rayinny
02-20-2003 18:21:44
 Re: Re: wd 45 baling hay in reply to big orange, 02-19-2003 19:05:24
We used to run a international #45 with a wd, plenty of power, the hand clutch is designed for stopping and starting when baling, the wd is a little fast in 2nd gear, I think the 2nd gear on a wd 45 is better matched for baling,
