Wd 45 hydralics
justin
02-19-2003 15:05:45
need to use wd 45 with double acting cylinder on a new holland 488 haybine was wondering how to run the double acting cylinder when i have only one outlet also how kuch does the hydralic resivor hold?
big orange
02-19-2003 15:15:18
 Re: wd 45 hydralics in reply to justin, 02-19-2003 15:05:45
If it's the lift cylinder you can remove one hose and put a breather in the hole and use it as a one way.Not sure of capacity but it will work the haybine just fine.Used a NH-489 behind our 45.
Gary
02-19-2003 15:45:16
 Re: Re: wd 45 hydralics in reply to big orange, 02-19-2003 15:15:18
You can run your fluid into n open center spool valve, send your return from the spool valve back to your reservoir and run both ends of your double acting cylinder to the open center valve. IH had this availibility in their manual on the LIFTALL used on the H and M Farmall.
