AC Model B Cylinder Pressure is only 30 lbs.
Les Lynch
02-19-2003 12:33:19
I'm in the process of trying to put an AC Model B back into service after sitting out in the weather for 5 or 6 years. The engine is not frozen up and I can turn it by hand crank without much struggle. But, all 4 cylinders register only 30 lbs. +/-. I've squirted oil in the cylinders. My cyl. pressure gauge is a screw-in, so there isn't any leakage that I can determine.
Does anyone have any ideas? Help very appreciated. Thanks very much, Les
Leslie Lynch
02-21-2003 17:04:10
 Re: AC Model B Cylinder Pressure is only 30 lbs. in reply to Les Lynch, 02-19-2003 12:33:19
RE: AC Model B Cylinder Pressure is only 30 lbs.
Thanks to all for the good ideas. I'll let you know how it turns out. Thanks again, Les
ac1948
02-19-2003 19:18:04
Are you checking compression by turning engine with hand crank? If you say all cylinders are 30# +/- just start it up and go for a ride! Jerry
steve
02-19-2003 19:13:16
rings are stuck in the piston groves. you can fill with oil and soak, then drag it around a little--maybe it will get better, i had to take my pistons out, broke rings off and bought new--from norm.
Mike R.
02-19-2003 17:27:55
You'll want to take the valve cover off and watch the valves to see if they have full travel. They're probably stuck? or not sealing ? and you're losing compression there. hth Mike
Chuck
02-19-2003 15:08:26
I am not sure, but my guess would be that maybe the rings are stuck and it is letting pressure around them u were smart by putting oil in the spark plug holes though, if my guess is right that might help the rings too! Oh and you also said that they were all around 30 pounds, so i wouldnt see how there is too much wrong with it since they all regerister about the same.. I am gonna stick with my guess about the rings. They say too put about a cap of a oil bottle in each cylinder.. Good luck
