Re: Paint and overspray on tires. WD-45
Larry806
02-15-2003 16:52:07
Hi you said your going to repaint the tractor just sandblast the tires also It does wonders for old tires almost gives them a new look & get's rid of all the old paint When we mount used tires we blast them first. When painting the rim's with the tire mounted take half in tape & go around the rim as close as you can after the first ring of tape you can use 1 in to make it go faster. We tape out at least 3 in when done use lacquer thinner for clean up
