Re: Allis B
Gatz
02-14-2003 12:13:55
(Somehow, previous answer did not get posted)
Jim, easiest way to tell engine rotation is to look at fan. Airflow goes from front of tractor to rear. Rotation of fan can only be one direction to accompish this and is likely to be clockwise FACING engine; which is also the direction of rotation when hand cranking. (Incidently, the PTO shaft turns clockwise when looking in SAME direction as tractor. For instance, observe a standard hammermill or feeder wagon, and the direction they are driven.) Assuming the engine does what you're describing with the ignition on, is the air that's coming out of the carb hot? Backfiring? If you're getting air blowing out the carb...something got out of time.
