Re: coil polarity
Steve in N.J.
02-12-2003 17:24:01
Mike,
Dan is correct on the hookup for positive ground wiring systems. Just switch the wires. And yes, on some coils, (depending on how tightly they're wound on the secondary side) will put out the correct amount of power(more)when current is being fed from primary coil winding to secondary coil winding the way it's designed. On some coils, if you check the spark after it's switched, you can actually see a more whiter type spark than yellow. Just watch ya don't get zapped! The situation is more critical with 12V systems if the wiring is run backwards. I've seen some coils fail after being hooked back up the correct way after they were run for a long time wired wrong... Steve B.
