AC-G rear hydraulic cylinder
Eric Egland
02-11-2003 05:21:37
Someone was asking about this item, don't know which board. The cylinder used on the G is the same as the third type used on the B tractor. A new rod and packing fixes these guys, rod didn't look chromed. I am going to use drill rod to make new rods for the several I'm rebuilding. Both items available from McMaster-Carr. The throttle valve used on the G is a psuedo-needle type. McMaster should have that as well, 1/4 inch size as it turns out. Good luck.
