AC-G fan shaft assembly
Eric Egland
02-11-2003 05:13:11
Well, they cut production cost when they put this together!! I am doing several at one time and have bearings coming today. I tried for 6 hours, with fire and a 20 ton press, but only shifted the fan hub 1/8 inch. Therefore, they get machined out to avoide damage to the hubs and new shafts out of drill rod. I guess they figured that keyways and hub nuts cost money. I'll post bearing numbers if they get the right ones.
Eric Egland
02-13-2003 17:23:45
 Re: AC-G fan shaft assembly in reply to Eric Egland, 02-11-2003 05:13:11
Well, got the right bearings (second try). Here are numbers: Front: Consolidated 88016 NR Rear: " 88503 NR Hope this helps someone, pretty quiet out there.
Eric Egland
02-15-2003 22:06:38
 Re: Re: AC-G fan shaft assembly in reply to Eric Egland, 02-13-2003 17:23:45
OOPS, I reversed the front and back numbers, but you need both anyway to do a proper fix. Got the fan off today, in a lathe. Still had to do the last 10 thou by hand. That metal was "married". Pulley popped right off!! Go figure.
DAVE S.
02-14-2003 15:05:40
Hi Eric, I'm working on one of these assembly's also. I got lucky, my brother inlaw works for a machine co. that stocks a large amount of bearings and they just happend to have them.I understand that Norms toys has these bearings on hand. He is on this post from time to time and is a good sorce for G parts.Good Luck on assembly!
Eric Egland
02-14-2003 21:16:37
 Re: Re: Re: AC-G fan shaft assembly in reply to DAVE S., 02-14-2003 15:05:40
Thanks, Dave. I've got three to do and have the bearing sets.
