Re: Oil Seal in Steering Pedestal
Bill Hires
02-10-2003 06:46:45
These seals are typical pressed in steel shell, lip seals. They can be pried, or driven out of their recess. The dual wheel tricycle front support has two seals, the others have one.If you have an Allis-Chalmers dealer they should be able to furnish this seal. If possible copy the part number off of the seal before removing it, or try to save the part with this number stamped on it. Any auto parts store should have a seal cross reference catalog for supplying the correct seal(s). If all else fails you can measure the outside/inside diameter for purchasing the seal. There are shims/washers to adjust the vertical spindle clearance. This is a good time to check for bearing/bushing wear. For more seal information go to, www.Infoseek.com and type in oil seals.
