Ignition rotor removal
mike b
02-06-2003 07:00:51
I have a fairbanks morris FMX magnito that was changed to a distributor. The rotor seems to be stuck on the shaft. When I pryed with a screwdriver, a small piece broke off. Any suggestions on a solvent or method to remove...any chance there is a screw holding it that I can't see?
thanks
Joe at 724 758 1006
02-09-2003 12:39:45
 Re: ignition rotor removal in reply to mike b, 02-06-2003 07:00:51
I also hove a FMX mag that Ichanged to a dist.
the roter should come rite off try a hair dryer
any good rust penatrent sometimes you gotta break them try DENNY'S Carb SHOP,at 937-368-2304 for
a new one
TX Denny
02-06-2003 13:36:11
There are no screws on the rotor. Since it should come off with your fingers, it may be the wrong one and was pressed on. It shouldn't be glued either. Since it is already cracked, replace it with a new one. Clean up the shaft before putting it on.
