Need G carb expert -Marvel Schebler TVS
Mark F
02-04-2003 20:57:26
I just removed and cleaned a Marvel Schebler TVS 13 that fits an AC G wheel tractor. There are 2 small holes in the bottom part of the carb (bowl portion). The lager hole about the size of a bb I was able to clean up. The other hole is about the size of a needle and it appears to have a very small brass sleeve, although it is so small it is difficult to tell. I inserted a small needle into this hole and it only goes down 1/4" and then strikes something solid. Also I cannot blow thru this hole. The carb has been dipped and cleaned..What is this small hole, and should air pass thru it? The gasket has a hole directly above the "small hole" ...Please help solve this mystery..Sorry for the long email, I didn't know how to explain it..Thanks, Mark
