D-17 vs wd45
Bud S
02-04-2003 12:18:02
I would like to know how close or different these two ac are.I'm wanting to move round bales and do lite work-[roto till and dry lot arena work.And some bush-hog work.thanks for your imput--BUD
gary
02-06-2003 13:57:45
 Re: D-17 vs wd45 in reply to Bud S, 02-04-2003 12:18:02
I guess if you just want the bigger tractor the D17 will do.My neighbor has a wd45 he plows mows and hauls round bales, seems to do just fine, another neighbor does his round bale hauling with his wd. But they are all good tractors just had to put my two cents out there for the wd45.
John (C-IL)
02-05-2003 06:28:24
The D-17 is the better choice for what you want to do. I would also strongly reccommend the series 4 with TPH and live hydraulics. The weight of the 17 will help you with carrying bales and the rototiller. John
Bud s
02-05-2003 08:02:36
 Re: Re: D-17 vs wd45 in reply to John (C-IL), 02-05-2003 06:28:24
Thanks john.Now i will know what to look for at auctions.--Bud S--aledo Il.
sHan maybe this will help you
02-04-2003 14:28:27
Allis Chalmers
D17 Manufactured: 1958 - 1967 Cost: $5,400 (1967) Horsepower: Drawbar: 36.7 PTO: 46.48 Engine: Fuel: gas Cylinders: 4 Displacement: 226 ci Manufacturer: Allis Chalmers Transmission: Forward: 8 Reverse: 2 Capacity: Fuel (Gal): 20.75 Cooling (Qt): 14 3-Point: Category: snap couple Tires: Front: 6.00-16 Rear: 14-28 Weight: 4659 lbs ===== ===== ===== ===== ===== ===== ==
Allis Chalmers
WD45 Manufactured: 1953 - 1957 Cost: $2,575 Horsepower: Drawbar: 30.1 PTO: 38.61 Engine: Fuel: gas Cylinders: 4 Displacement: 226 ci Manufacturer: Allis Chalmers Transmission: Forward: 4 Reverse: 1 Capacity: Fuel (Gal): 15 Cooling (Qt): 13 3-Point: Category: snap couple Tires: Front: 5.50-16 Rear: 13-28 Weight: 4465 lbs
