Re: MAIN BEARING SHIMS- BEARING CRUSH
DanD.
02-03-2003 16:40:40
One question. Is there any lubrication in the bearings? When you overhaul an engine, you should always put engine rebuilding grease in the bearings to provide lubrication at first start up. If the bearings are dry, I'm sure it will turn a little hard. If I remember correctly, bearing clearance in a D17 is supposed .001-.003 so it should be ok on your B. Consult a shop manual though to make sure.
Trumble
02-05-2003 16:46:00
 Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to DanD., 02-03-2003 16:40:40
Line bore the block, and forget the shims .....
PK Avritt
04-04-2003 06:54:51
 Re: Re: Re: MAIN BEARING SHIMS- BEARING CRUSH in reply to Trumble, 02-05-2003 16:46:00
Absolutely right. Line bore is the only way to fly.
