Need help replacing WC fan belt
Garry
02-03-2003 08:30:15
I changed from a generator to an alternator and need a longer fan belt. It appears that the tractor needs to be taken apart to replace the belt but I know that can't be. The belt goes around the crank. Does the manual crank rod come apart? Any help will be appreciated. I believe this is a 1940 AC WC.
Zonie
02-05-2003 20:38:36
 Re: Need help replacing WC fan belt in reply to Garry, 02-03-2003 08:30:15
I just pulled the belt off my WC the other day, I found the shaft for the crank starter was in the way also. I checked and found the shaft wasn't all the way out away from the front pulley. I just pulled it forward and the belt slid past it, it was a tigght fit though.
Garry
02-07-2003 10:31:24
 Re: Re: Need help replacing WC fan belt in reply to Zonie, 02-05-2003 20:38:36
Thanks Zonie, I'll try to pull the shaft out.
JMS/MN
02-03-2003 21:56:25
Drain the coolant, remove the lower radiator hose, and replace the belt. New belt should go past the shaft for hand cranking with no problem.
Garry
02-04-2003 06:22:40
 Re: Re: Need help replacing WC fan belt in reply to JMS/MN, 02-03-2003 21:56:25
The shaft goes into the engine and out the front of the tractor. The belt is around the shaft and that is the part I cannot figure out. It appears that the front will have to be taken off unless the shaft pulls away from the engine.
JMS/MN
02-08-2003 07:58:20
 Re: Re: Re: Need help replacing WC fan belt in reply to Garry, 02-04-2003 06:22:40
There should be a spring around the hand-crank shaft, which holds it away from the engine pulley. Spring goes between front casting and a flat-iron bracket.
Larry
02-04-2003 15:08:48
You should be able to pull the shaft forward and clear the pully.
Garry
02-07-2003 10:32:54
 Re: Re: Re: Re: Need help replacing WC fan belt in reply to Larry, 02-04-2003 15:08:48
Thanks Larry, I'll try that.
pj
02-03-2003 08:36:14
You can either take the bottom radiator hose off to change it or pull the hood and rad.good luck
