How do you tell if a Camshaft is any Good or Not?
AWB
02-02-2003 17:13:05
I am rebuilding an Allis Chalmers Model G engine. How can I tell by looking whether or not the camshaft needs to be reground? Thanks, AWB
steve
02-04-2003 16:35:15
 Re: How do you tell if a Camshaft is any Good or Not? in reply to AWB, 02-02-2003 17:13:05
use a micrometer and measure the diameter of each lobe in the "big" and "small" directions. all 4 intakes should be the same, and all 4 exhaust should be the same. you can subtract the small from the big and get the valve lift. if any numbers are different by .002 the cam is worn. if the numbers are all with in .005 and you dont feel any breaks or sharp edges, i would reuse.
steve
02-04-2003 16:34:34
JMS/MN
02-03-2003 21:58:12
If it feels rough when passing your fingernail across it, it needs work.
