52 ac ca doesnt move
scott
02-02-2003 05:13:45
when i let the clutch out it tries to move but binds up and kills the motor.took the side plate off all the gears look like new.could it possibly even be a brake hanging up.first tractor so im not real noligable,still waiting on owners manual.
thanx alot for help on the not running part.
steve
02-02-2003 06:01:36
 Re: 52 ac ca doesnt move in reply to scott, 02-02-2003 05:13:45
--wiggle ths shift lever and make sure it moves freely and not stuck in 2 gears at a time.
-- is it below freezing where you are at?? could be wter in the transmission froze? maybe drain the trans oil and look.
--jack up 1 wheel a couple inches and try to roll that tire. one on the ground is stationary, other should roll-- that checks for stuck brakes.
--then jack up other wheel and try that side.
--push brake pedal up and down, do they appear to work?
scott
02-02-2003 18:13:53
 Re: Re: 52 ac ca doesnt move in reply to steve, 02-02-2003 06:01:36
took tire off wheel would not turn.had side cover off, slid the first gear inside cover on top and the wheel spun freely.started tractor still would stall when clutch was released.getting my service manual tommorow hopefully that will help some too!
big fred
02-03-2003 12:48:33
 Re: Re: Re: 52 ac ca doesnt move in reply to scott, 02-02-2003 18:13:53
Perhaps you have a PTO problem? If your transmission is not in two gears at once, but your PTO is engaged, then a PTO problem or a hydraulic pump problem might be the next thing to investigate.
scott
02-02-2003 18:13:40
