Model B Main Bearings
H-MAN
02-01-2003 14:33:47
Hello, I had my crank turned .020 and purchased .020 under bearings. I bought new shims from sandy lake and used new set under each cap. I used plastigage under each main cap and have a reading of .003 on all three bearings. Is this sufficient clearance? Thanks
Joe
02-02-2003 16:06:37
 Re: Model B Main Bearings in reply to H-MAN, 02-01-2003 14:33:47
I rebuilt a AC C last year and had the main and rods cut 020 the book says clearance should be
.001 to .002 .003 maybe a little to much it only holds 20 psi oil pres. so you may loose some pres
make shure the shimes are not hitting the crank
recheck dry!!! this is very tricky duble check
shim thicknes this is the hardest part of this rebuild once this is done clean all parts and coat with STP tork. each one and turn crank shaft
after each one good luck PS mine was .002
and runs great Joe
Butch (OH)
02-01-2003 18:02:30
Just curious, how much were the new shim packs?
Thanks
H-Man
02-01-2003 18:37:50
 Re: Re: Model B Main Bearings in reply to Butch (OH), 02-01-2003 18:02:30
Their not cheap I dont have the receipt here at home. But the total was about thirty dollars. And part of that was shipping.
Dick L Ya got er
02-01-2003 16:08:07
.002 is what you want to shoot for. .003 will work.
H-Man
02-01-2003 18:50:09
 Re: Re: Model B Main Bearings in reply to Dick L Ya got er, 02-01-2003 16:08:07
Thanks Dick for all your help. All of your past postings & your fotki album, have saved me a lot of hastle. Your pictures remind me of my our place. We have A 49 model B, 44 model C, & a 52 Model WD with 45 engine. Again Thanks - Harold
