HEAD BOLT FT. LBS.
DAVE S.
02-01-2003 05:13:47
I need to replace the bearings on the fan shaft on my (G). I will have to remove some head bolts to do so.What is the correct ft. lbs for the AN 62 engine?
Plant Doctor
02-01-2003 13:33:17
 Re: HEAD BOLT FT. LBS. in reply to DAVE S., 02-01-2003 05:13:47
Dave: If I remember correctly, the head bolts do not have to be taken out to remove the fan bearing supports. The "G" came from the factory with 4 threaded studs with nuts on to hold the fan supports. Unless someone has been into this tractor before you, all you need to do is take off the 4 nuts. There should be nuts under the fan bearing supports to keep the head tight. If someone has been into this before you and you do have to remove the head bolts, I think these bolts go into the water jacket, so when you at ready to reinstall them you should put a sealing compound on the threads to help them seal off the water. Also, originally the threaded studs with nuts on holding the fan supports were long enough that after removing the nuts it was tricky getting the fan shaft and fan supports out. The fan would hit the radiator shield and you couldn't get enough height to get everything apart making it necessay to loosen the shield and/or the radiator. Did you get the fan bearing yet? I visited a lot of bearing supply houses before finding one. Good luck.
DanD.
02-01-2003 06:12:01
53-57 ft. lbs. per I&T Shop Manual
