Re: WD Backfire
Dave K
01-30-2003 11:58:49
Fresh fuel?
Does fuel run freely out of carb with drain cock open? If not, plugged fuel tank drain, filter or lines.
If magneto, clean up or better yet replace points and condenser. be sure you hear the "snap" from the impulse on the mag. Mine did this and it was the condenser in the mag. If no "snap" then impulse spring is probaby bad although dirt and cold weather can also keep it from snapping.
dave
DonLC
01-31-2003 04:38:08
 Re: Re: WD Backfire in reply to Dave K, 01-30-2003 11:58:49
Sounds the wrong plug is getting the fire.Spray the inside of the cap and the wires with starter fluid....let it dry good,we don't want to start a fire....this will get rid of the moisture in the cracks.If you have been ranking on it a while, you could have gas standing on the pistons,,,,every tine the pistons come up the plug gets dipped in liquid gas....remove the plugs and blow the cylinders out.....burn the plugs clean with a small flame.....
DonLC
01-31-2003 04:37:44
