Wd/wd45 stroke
Peter
01-24-2003 12:38:48
How is the stroke increased in the wd45? is it the crankshaft or the connecting rods? I see a common listing for both cranks and rods in my parts book and they both have a 4" bore right? Is it possible to change the 201 engine to 226 with an original wd block? Peter
JWS
01-24-2003 13:33:51
 Re: wd/wd45 stroke in reply to Peter, 01-24-2003 12:38:48
Stroke on the 45 is 1/2 inch longer. this is done by increasing the throw on the crank by 1/4 inch. The 201 block can be brought up to 226 specs by using the 226 crank. The rods have nothing to do with dispacement.
Tom Jensen
01-26-2003 08:45:24
 Re: Re: wd/wd45 stroke in reply to JWS, 01-24-2003 13:33:51
JWS is right. However, if you increase the throw and use the same rods, the piston will move higher in the block. Perhaps too high!?! Check it out.
JDGnut
01-27-2003 14:11:49
 Re: Re: Re: wd/wd45 stroke in reply to Tom Jensen, 01-26-2003 08:45:24
Not sure about the gasser.. but the diesels just use a shorter piston, common rods.. (between the D17D and WD45D)Remember the amount increased in stroke.. the uppward movement will only be increased 1/2 that amount. Ex 1/2in longer stroke.. the piston travels .25 further up.. and .25 further down.. but increase the compression.. Good Luck
JDGnut
