24 volt positive to negative ground
Charlie
01-22-2003 08:33:41
I have a G-12 track loader and I am wondering how if possible to replace the generator with a 1 wire negative ground alternator.The system is 24 volts. Also have problem with cold starting.
02-11-2003 20:34:39
 Re: 24 volt positive to negative ground in reply to Charlie, 01-22-2003 08:33:41
Changing to neg ground won`t help. If it won`t start check the charging system and check the starter.
steve
01-22-2003 16:32:45
the 12G was a good old loader in its days. In the late 1970-1980 era ALLIS used a 24 volt alternator on all the construction equipment they built, loaders, dozers, graders, etc. Most were an industrial DELCO unit. You probalby dont need an industrial unit (more money). I think i would go to NAPA and ask them what they have for some of the lighter duty trucks these days. Some of the 2 to 5 ton trucks are 24 volt, as is all construction equipment. You could use something for CAT or IH, etc. I bet most of them are made by DELCO anyway. as for adaptability, no problem. YOu starter will be fine, diesel dont know the difference. Lights are already 24 volt. Switching + for - should not be a problem. Some alternators are not single wire, dont let that change your mind if it is a 3 wire. Might also try www.ibdozing.com and ask them guys were they get 24 volt stuff.
