G Tranny Fluid Service / Repair
Mark F
01-20-2003 11:59:45
I pulled the engine out of the G and it's getting rebuilt..I'm putting in a new throw-out bearing and clutch assy. I'm not sure how the bearing comes off of the clutch arm in the bellhousing. Also it appears as if there is a seal behind the throw out arm...on the back of the bellhousing..I assume this should be replaced also..What type of tranny fluid goes in the G? It has factory hydraulics...Thanks for the help..Mark
Ps..Who sells the best service repair books?
steve
01-22-2003 16:42:57
 Re: G Tranny Fluid Service / Repair in reply to Mark F, 01-20-2003 11:59:45
the G originally had 20 wt motor oil in the transmission. It is the same transmission as the "B" and these days should be using hy-trans 20 wt combination hydraulic transmission fluid. You can get a 2.5 gallon bucket at Wal Mart for $12. Yes, any seal should be replaced on disassembly.
