Allis C trans problem
Jim
01-20-2003 10:03:37
I have a 1944 C. A shim from behind a diff. gear in the carrier was in the bottom of the trans case. Is this something to worry about? the gear it came out from behind has little movement. Are there any tricks to fixing it? I am a Case and IHC man, so Allis is still a little forigne to me. This tractor spends it's life on our farm hauling wagons, running elevators, and powering a Woods 6" belly mower.
Gordon
01-20-2003 16:52:38
 Re: Allis C trans problem in reply to Jim, 01-20-2003 10:03:37
The pin that holds the pinion gear in place must have came out.If the gear is not held in place it could jam and wear the gears.Generaly that shim is a thrust washer,but it can be a shim I do not have my books here to tell you for sure.Take the back housing off and you sould see everything.
