Re: Tractor won't move
Gear lube too thick
dave k
01-19-2003 12:39:39
You have water in the tranny probably, often gets in through the shifter boot and freezes up in cold weather. Stiff gear lube won't keep tractor from moving and will thin when warm. You gonna have to put it in a heated shed and drain the lubs.
Dave
Eldon
01-19-2003 17:25:37
 Re: Re: Tractor won't move - Gear lube too thick in reply to dave k, 01-19-2003 12:39:39
I parted out a model C a couple of weeks ago.....when I drained the transmission I got about 3 gallons of water and 2 tablespoons of oil!
mj
01-19-2003 12:49:24
What they said and replace the shifter boot, if it's bad. Keep the shiftlever area covered with something to catch the snow and rain if it sits outside. My uncle tore up the clutch disc and flywheel trying to 'break loose' his WD-45 after it sat out and froze!
